map light replacement
digphisher
Does anyone know how to replace the map light bulbs? I can't figure out how to get into that housing.
Thanks for the help.
i plan to change my lights too. going to try to do my own LED mod to make my lights brighter since my DOME light isn't as bright as i thought it would be. but here's a picture i found on 4runners.org. just peel off the plastic cover on the letter T then unscrew it.
Mine looks a little different than yours (mine's a 2005). I have the 2 map lights, and the sunglasses holder in front of them. I'll check to see if I have a plastic cap.
Just use a flat head screw driver to pry up one side of the lense itself. The lense will pull right off and then you can change the bulb.
There's the picture i posted up. That's for a 3rd gen T4R. Just use a flathead and get that plastic piece out. then you use a phillip to unscrew it.
I followed sharp4runr's advice and just took a small flat head and popped out the clear lens from the outer part of the lens, and they just popped out. I replaced the lights with red ones. In the dark, they do just what I want, give the passenger enough light to read and look for something with out blinding me as the driver.
I got mine at Advance Auto Parts for like 2 bucks. They aren't the red glass, but I think are painted red. I couldn't find the red glass bulbs anywhere except online, but I didn't want to wait.
Digphisher...did you ever figure out how to access the map lights on the '05 4Runner? If so, please let me know...Thanks
I replaced the passenger side with a high intensity white LED and the drivers side with RED LED for night use. The high intensity white illuminates the whole front seats area!
Bob
