Max tire size with daystar lift
Larryota
I just purchased a 2.5 inch Daystar spacer lift I have 17 inch wheels I’m looking for the max size tire that you can put on with this lift currently there is 265/65/17 on it at stock height
So can’t figure out between 285/70/17
Or 275/70/17
I do want to put the one that will fit with the max size but not cause an issue with the most of you go with
Can someone give me a definitive answer I’d like to try to order tires just not sure what size I should be going with 2 1/2 inch Daystar in the front one and a half inch the rear.
265/70/17 Will definitely fit just trying to figure out if there’s a size bigger that will fit without a problem if anybody can help thank you
