Maximum Tire Size on 2006 4runner
Bfg a/t ko2
I have a 07 sport 4wd and I plan to swap the XREAS for 5100s. What would be a good setting to run on the front while keeping stock coils? Also will 265/70r17 BFG K02 fit with this setup? Thanks
If I go with a 16inch wheel how big of a tire can I put without scraping on stock height? On a 2006 4 runner sport 4wd
Double check that a 16" wheel will fit. I suspect the brake components are too big for that size wheel, so you might need to downgrade to base model parts too.
But either way, anything that results in greater than a 32dia x 10width will rub without mods.
Let me get this straight...you told them that you had found them at $165 a piece somewhere else and they matched it and they also bought back the dunlop stock tires?? so basically the cost per tire was $165-$50=$115 a tire? Any chance this was in atlanta??? I going to a discount tire the weekend for sure.
Thanks,
the tires will hold but what radius they could understand from the photo
Upgrading Rims and Tires 2014 4Runner limited
Hey guys, new here. I have a 2014 4runner limited with leveling kit. Going to get rid of the stock 20" rims and move to a 18x9 with 285 / 65 R18 Open Country A/T III. Will these fit and also what offset will i need? Thanks
DJNutshell
