Maybe a lift - if the Tax-man is kind..
gdvan01
Mostly for the "that looks bad-a$$" effect and be mechanically sound as well.
Will I be doing any crawling? In the words of Jerry Seinfeld....."not bloody likely!"
Primary goals - run 17" 285's; keep stock UCA's; properly aligned front.
Minor trimming/mudflap removal acceptable.
Haven't narrowed down wheel/tire combo yet.
2017 SR5 Premium
(4) Bilstein 5100's, front at .85
stock springs (currently)
In no particular order I've come up with the below 3 options for my needs:
1 - Wheelers springs: T1 up front, T13 rear
Set Bilstein's back to 0 (unless this is an issue)
2 - Daystar 2.5 lift kit (spacers)
Approx. 2.5" front, 1.5" rear
3 - Keep Bilstein's fronts at .85
add 1.5" Cornfed spacers front
add 1" Cornfed spacers rear
I don't know if moving the C-clip on the Bilstein's after the initial setting is an issue or not. If so, I guess I'm looking at #3.
Barring any issue moving the c-clip, I'm thinking the first choice may be the all-around better choice. If I already have 'better' shocks I might as well go with' better' springs considering I'm going to larger tires.
Makes sense to me at least...
So whatcha think? I want the suspension to be stable for what it is, it won't see any hardcore off-roading but would like to for it to last several years under average conditions.
If you want a lift large enough to comfortably fit 33" tires, your alignment will be out of spec, namely the caster. The only way you will be able to get the caster back into spec is with adjustable/aftermarket UCAs that come with more positive caster built into them.
lindwlson982
