Message Alert Question
Stewchoo
my VSC TRAC and VSC OFF lights have recently come on, and the owner's manual is far from helpful...what exactly does this mean and is it serious?
What are you driving?????
Are you driving around with your center diff locked??? Dash button on the left side of steering wheel.
If so, push the button and unlock it before you damage your drive train.
Both those lights came off after I got my Sulfur TSB done. Apparently it was a faulty sensor that they had to repair.
If you've locked the Center Differential there should be a little yellow dash light that looks like 4 wheels with an X in the middle and the VSC OFF light will be illuminated. VSC TRAC shouldn't be on at the same time.
I'm referring to a 4th Gen, not sure what you're driving...
