Middle interior light replacement
parsky1
Member
Does anyone know where to get a replacement dome light in the fawn/tan (FG42) color? I have the rear audio display and my light lens is cracked and part of the housing that bolts into the headliner. Everything on eBay is stone/gray. Amayama couldnÂ’t come through. The GX470 has the same light but their tan is called ivory and IÂ’m not sure it would match either.
Can you snap a photo of what you're referencing? I think I have the same setup but I'm trying to confirm...I'm wondering if you can just acquire the lens and swap it out from the GX47?
Search for AZ 4Runner Parts on FB or eBay. Joshua Beletz dismantles 4th gens and has tons of parts based out of Phoenix AZ area.
I may be mistaken but I think the cutout in the headliner is bigger with the video system/light assembly and therefore the normal light will not cover the cutout.
Mine is similar, the plastic trim/surround is cracked is the whole assembly is slightly loose.
It is bigger for AV so the std light is a no go. I started combing eBay and might have found a scrap yard with one. It hasn’t been pulled but I got the VIN and confirmed it’s FG42. Hopefully it isn’t damaged. Some of these parts are getting hard to find!
AndiGarage
