Mike's (Redswan) 2005 4x4 sport edition
[MENTION=50591]gaterose[/MENTION] should be able to help you on the pre-06 Satoshi's. I'm not sure what else could help you though...e-fan maybe?
That is the idea I was trying for. I found [MENTION=72408]Mytoy4[/MENTION] 's write up, that should help a lot. Hopefully it turns out that nice.
Thanks, Redswan! kkz is right though, the pre-06 is a bit more difficult then the one I made.
Good luck either way! I look forward to seeing it when you're done. Love the Satoshi :)
I have a writeup here for the '03-05 satoshi - http://www.toyota-4runner.org/4th-gen-t4rs/103653-03-06-retrofit-satoshi-grille-writeup-picture-heavy.html
I think the best bet is to use an '06+ grille and trim it like emelianenkov did, I don't think the smaller '03-05 grille looks as good with the mod. It's also A TON more work to get the '03 right.
I agree. Here is how I did mine - it sucked and i had to break the spot welds on the grille subframe.
i found the 06+ grille on amazon for a song. I made the bracket from some 1/4" aluminum and there's more trimming needed on the bottom of the sub frame.
No prob, good luck if you decide to take it on!
If you need any advice or assistance feel free to PM me, I've built about 8 of these now so I have a bit of insight.
I can vouch, he's the man :thumb:
also i can give you more pics of the way i cut the subframe if you want them.
well I didn't go full shitake, but I did get the new grill mounted up. I didn't have to trim much to get it to fit, just a little plastic off of the bottom corners. I did have to remove the lower eyelid pieces off.
I guess I will trim it all up and epoxy in the inset after my DV trip this weekend.
Mike I've told you before, I'll tell you again.....I really dig your 4runner. In fact, I'm using what you've done as inspiration for mine. Mine isn't 4 wheel drive and I have the V8 but stance wise, that's how I want mine to look. Hopefully before the end of the year.
:thumb3:
Mike, how do you like that light bar? Is it a spot/flood?
Morris, It is great It is about 2x the range of the high beams. It is a spot, flood combo (60/40) that i picked up from a place called exploration outfitters in Durant, OK.
Thanks man. I have been looking at the same one on their site. I think you made up my mind....:usa2:
If you get a chance, could you measure the actual length of the light bar? I know it is listed as a 40" but they aren't always those lengths as they are listed.
**edit**
Never mind I found it. It is 39 1/2"
Nice video Mike. Gave me flashbacks of our last DV run. Pics don't usually accurately portray how steep the drop offs are or how narrow the Lippincott trail is but there were some parts of the video that did a pretty good job. Looks like another great DV trip!
