Mild squealing when accelerating. Only 3000RPM+
Inate
Hey guys,
Just bought my first 3rd gen. A 97 Limited Edition with auto, 4wd, rear locker, the works. 272xxx Km's.
I picked up the truck about 3 weeks ago, and it's been rainy ever since, but this last week has been ridiculous heat(35c+) so I've started to drive with the windows down more. During this time I've been noticing a squeal outside of the vehicle only when the truck is under, well, hard-ish acceleration. Think merging into highways speeds. Not foot to the floor, but mid throttle I would guess. I only hear the squeal start at 2900-3000+ RPM. Under moderate acceleration(like I normally do) it shifts at about 2500 RPM and I never hear the sound.
I drive daily without the "ECT Power" switch on. I've been able to reproduce this sound reliably during hard acceleration.
Just curious if anyone has any ideas where to point a mechanic, or any tips to help alleviate this "issue". If it even is an issue.
The squeal starts high pitched and increases in frequency as the RPMS get higher, only stopping once the tranny has shifted into a higher gear.
I appreciate any input or ideas. This truck is my new baby and I just want to take care of her. I have plans, but first and foremost is maintenance and making sure everything is up to snuff!
Perfect, one thing to move up the to-do list!
I'm getting the timing belt/water pump done in a week/two, so I'll get all the belts changed over when that happens too... Among other things.
Did you resolve your squealing issue?
Is it a squeal or high pitch whistle, I had the whistle under the same circumstances... mild-hard acceleration... kicks in the stops when shifts up...
turned out to be an exhaust leak, new muffler took care of it...
help
Bumping an old thread, sorry.
Lately I have been getting a high pitch squeal sound at high rpms (around 4k) and when I turn the wheel left or right at parking lot speeds.
Any help would be greatly appreciated.
Edit:02 4wd with 150,000 if it matters
Tighten or more likely replace power steering pump belt. Also check power steering fluid level and top up if necessary.
Buckaroo
jisoo200
