Mileage dropped
steved
I have an '03 SE v6 with 60K miles. I drive about 100 miles per day back and forth to work. 95% is highway driving. I was getting close to 400 miles per tank. This past July I bought a set of Revos, same size as stock. I didn't notice a difference in mileage then. Around October my mileage has dropped 25%.
I have asked the dealer when it was in for routine maintenance to check this out. Of course they found nothing and blamed the tires.
I know that hear in the Northeast they use oxygenated-fuel for the winter months and you lose performance. But never has it been this bad. I have tried to watch my driving habits as well and still the mileage suffers.
Any ideas what could be going on? I will be back at the dealers next week for the 60K miles check up.
Not sure about NJ, but in MA with the temps bouncing between 50 degrees during the day and 11 degrees at night, my tire pressure fluctuates alot. I put them at 38 on a day when it was 50, then checked them last night and they were at 29-30. Not enough for the sensors to fuss over, but enough to drop my gas mileage. I don't really feel like filling up the tires on a daily basis, so I leave them until the weekend and I will top them off then.
Spark Plugs were done at 30k, correct?
You are due for a new set at 60k. See if the new plugs make a difference. Make sure the dealer is using the correct plugs.
Replace the air filter.
Change the rear diff gear oil. Go synthetic if you can.
workingwheelswnc
