Mirror Swap 10'-13' to 14'+
johnnyd2723
Good Morning All! I really dig the mirrors on the 14+ Runners and the lighting upgrades available for these are too cool! I've been searching the threads to see if 14'+ side mirrors are a direct swap with 10-13,specifically in my case a 2010, but haven't found any info specific. Has anyone made this swap and is direct or modifications required? My Runner has heat, puddles, and turns. Thanks in advance :thanks:
Yes they are a direct swap, I did it on my 2011 as part of the folding power mirror mod. However I just have heat, no puddle, no turn.
The connector was exactly the same for me in this case.
I think as long as you get 2014+ mirrors with the same features. (heat, Puddle, turn) You should be fine.
The hardware is identical, bolts right up, the only issue would be the wiring and the connector plugs. Best way to know for sure is to pull yours and look at the connector plug, then look for the mirrors you want and compare the plugs.
Nice! Thanks for the info. Do you remember where you got your mirrors at?
Mike Sargent
