Misfire/lean at high altitude
catalina34
I am getting a lean bank 1/misfire code when I drive to the same mountain town. It throws the code at nearly the same place each time. Otherwise I never get the code. In advance, the MAF is clean and the fuel filter is relatively new.
Seems to me you have unmetered leaks or vacuum leaks which are so slight they only show up where the air thins out.
seltzernator
