Crackership
Hi all,
I recently purchased a 1996 Limited with 260k on the clock. I got it for a steal with a P0302 CEL for missfire cylinder #2. I've read every thread I can find that might help, but I've still got the missfire. I'm hoping someone can point me to something I've overlooked.
Here's what I've done so far:
- checked all the vacuum lines, some don't look great but no apparent leaks
- cleaned the MAF
- replaced the spark plugs (yes, got the correct 2-prong guys)
- replaced spark plugs wires
- replaced the coil for 5 and 2
- cleaned the throttle body and IAC
- Bench tested the IAC and it checks out
- replaced injectors
The only things left that I can think of are compression test and then check the timing. Any other ideas?
TIA!
- cleaned the MAF
TIA!
