Missing A/PUMP 50A and AIR SUS 50A fuses.
Just discovered that my fuse box is missing A/PUMP 50A and AIR SUS 50A fuses. Is there any cause for alarm? And since I serviced my car, it has been showing check engine, VSC TRAC, VSC OFF and sliding car signs. Upon scanning, it showed P0420 and P0430 catalyst error codes. What should I do? I've serviced the injector, checked the exhaust and the spark plugs. Yet no change.
You're probable missing the fuses because your missing the air suspension they go to buddy. But if I was a thief and stole the air ride, I'd steal the fuses too - just to keep it classy.
If you don't have the air suspension, you won't have the fuses to support it.
Try swapping out the gas cap for a new one.
