Mobil1 gear oil in Canada
caspermj
Can anyone help me source this stuff??? I've been to every place that carries M1 products and they all say they can't even order the stuff in for me. I'll get another brand synth gear oil if I have to but my oil and trans fluids are M1 and I've had such good luck with them I wanted to keep on using the M1. I'm in Nova Scotia and have tried Canadian Tire, Walmart, Home Hardware, NAPA, Car Quest and some local garages! I don't know where else to try??? Anyone know where to get some?
i use mobil1 for my motor but as far as the gear oil herd allot of complaining at toyota nation about it... granted there running 05 and newer Tacoma's with the limited slip rear ends there putting the additive in and still get binding ... IN my 05 trd tacoma i have Redline syn in the transfer case and both diff's. I put it in at 18500 miles my truck turned 53k on the way to work. I picked up a 99 4Runner limited with 49k on it 2 months ago, i just finished last week changing it all to the Redline Toyota dealership in Penn. did the trany (auto) and put new diff. breathers on plus some more things GREAT ! Dealership glad i found them > But if ya want the Redline you can order it on line And good place to look for it would be a Hot rod shop around your area they might have it Hope this helps Red line is the 1 for all the hot rod guys (pro's) http://www.redlineoil.com/ http://www.summitracing.com/ < ------ ships to canada
I ran into the same issue. Mobil is Exxon which is Esso in Canada. The only lube shops or garages that stock it and do it here are Esso stations. I wanted to do it myself so I went the next step and ordered from a local Esso wholesale outlet (they also sell heating oil, etc...) They had to order it in and I actually got a better deal than retail.
Re: Re: Mobil1 gear oil in Canada
Never thought of that! Will check it out tomorrow, thanks!
