Molle Panels
Attached MOLLE panel clips or straps for RAGO shelves, etc?
Hello all. I have a set of RAGO MOLLE panels and the shelf system in my 4runner. I love the setup and it works great. I'm looking for some kind of strap or clip product that I can use to attach bags, gear etc?
What I'm after is something that will stay connected to the panel when I detach the gear.
The Quickfist is the right idea, but it's only good for things like hatchets, flaslights, etc. Original QUICK FIST clamp - Item #10010
Regular MOLLE straps are okay, but they detach from the panel when you remove the bag: Amazon.com
I want to be able to detach a bag from the panel to use it but have the mounting device STAY ON THE PANEL.
Any suggestions? FYI, velcro works for a few months, and then doesn't work, especially with heavier bags like recovery gear, etc.
b
e
n
b
e
n
I zip tie my molle bags and use magnetic velcro thingamabobs for my compressor hoses:
Amazon.com
Amazon.com
You could potentially use the quick fists, but we used to take D-rings and clip them to the shelf and then clip on the grocery bags. Maybe see if you can find some straps with D-rings on both ends! Hope this helps guys.
Oh yeah, D ring molle adapters, you just have to use a carabiner with it.
Amazon.com
I have Victory side panels and the shelf. It sits up high enough I've never had any vision out the back issues. I keep stuff tied to the panels with little bungies, and bought some magnetic floods from Tractor Supply that are solid as a rock. Very happy with it.
I don't have much to store, but would just like to hang a bag or two that hold a hitch and a rope maybe? Not looking to cover the windows. Is there anything besides the rear hatch for the back cargo area? Like maybe just the lower half of the Cali ones? Those would just sit above the trays and hold a bag in place.
I've been looking at the Cali Raised too. Wondering if the molle's cause too much of a vision block. Any thoughts?
erinobr2000
