Moon Roof Lube.... what are you using?
MeBe4running
My moon roof/sunroof has now got to the stage that it wont even close. The factory jelly like lube has dried out. I have used some WD40 just so I could get the glass to close (raining).
So any suggestions on where to get some of that factory lube jelly Toyota use? AutoZone, Napa, O'rielys, Advance auto parts, Amazon?
Oh, keep the KY jokes to yourself :pound:
Anything silicone based (or lithium based). Petroleum based will not work well with the gasket.
BENZWERKS SUNROOF LUBRICATION AND MAINTENANCE - YouTube
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/0FrNi9XA9UU?hl=en_US&version=3&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/0FrNi9XA9UU?hl=en_US&version=3&rel=0" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Mobil1 synthetic grease is what they use.
Okki
White Lithium Grease is what I use on all vehicle doors and slides. It is in an aerosol can with a straw type applicator.
Great, thank you guys, you saved me a trip! I will order some cans now.
[MENTION=66316]1engineer[/MENTION]
OFF TOPIC: Greg, went mountain biking for the first time the other day, had a blast. Have you ever done any of trails at the US white Water Center Mountain Biking | U.S. National Whitewater Center
Its some good stuff!
Rode 'em all this past weekend. Check your pm.
On-Topic: You don't have to order it. NAPA, Advance Auto, WalMart and most places carry it. It's in a blue spray can.
white lithium here. I use that stuff on lots of things like screw drive garage door openers etc
Bike Chain lubrication is mainly what I use the white lithium for in my garage.. and my crew drive garage door opener.
Okki
Mine got very noisy and the lube dried out. Never quite got to where it wouldn't operate, though. It seems to be the result of not frequent enough usage.
I use lithium, too, and it took a while to get everything squared around but once I got in the habit of operating the moon roof frequently, it's been trouble free ever since.
I prefer a silicone grease like dielectric grease as it doesnt dry out as quick as lithium, which seems to become abrasive when dry.
Would you guys recommend cleaning out the tracks before spraying in the new lithium grease, or just try to get into the habit of maintaining it every once in a while with a spritz or two?
Plumbers grease. It's silicon grease and you can get at lowes in the plumbing section. I use it on all o rings, etc. as well.
leolediola
