MOON ROOF PROB
swegen
Member
2008 limited X 220000 MILES WAS DOING GREAT JUST GOT PAINT POLISHED UP AND THE MOON ROOF IS HAVING AN ISSUE.
Opened it this morning (almost never use it) sounded weird, closed it , opened it again and now is stuck with driver rear corner up.
tracks were cleaned a month or two ago but now its stuck like pass side drive is busted!. motor seems OK but whatever makes it go
back and forth and up down is broken. cant see any mechanism to determine whats going on so kinda stuck.
duct taped up due to weather forcasting showers. Where can I find a nice assembly drawing or video or something which I can use
to see what the parts are and what they do.
TIA
Tom in 60193
TIA
Tom in 60193
Did your moon roof get removed when they painted it or whatever? I replaced mine cause it was rusting out and it opened ok but when I closed it got like stuck and then would make a loud pop before finally closing. Turns out there's these small metal rails that freely slide back and forth on the rails under the moonroof. I didn't slide one piece back to where it should have been when installing the replacement glass, and it was getting stuck on that when closing until it popped over it. Might be worth checking that.
TRDZRehder
