moon roof restoration (OE sunroof glass)
slacker
this would apply to ANY rare glass , not just the moon roof .....
so I have a couple of these for my Trekker . Both are ok , but have scratches on the glass ... So I decided to try "fix" the worst one ..
This one was from a unit I parted a few years back .. It was rolled , as you can see the deep scratches on the glass .
SSPX0978.jpg~original
so first .. I put some tape on the back side , so I would know ware I'm working
SSPX0979.jpg~original
then I brought out the DA and started to sand it with 220
SSPX0981.jpg~original
it as far as I got today ..
Im very sun sensitive so I always tint mine like double limo, it doesn't fix the scratches, but you cant see them any more. I hope your trick works out.
got a little bit more done today
wet sanded with 400G
SSPX0984.jpg~original
wet sanded with 600G
SSPX0985.jpg~original
wet sanded with 800G
SSPX0986.jpg~original
and removed the tape
SSPX0987.jpg~original
just need to polish to remove the haze
SSPX0989.jpg~original
thanks ...
I spent a few more hours sanding .. and polishing .. 6 hours total so far
SSPX0992.jpg~original
reflection is awesome , but there are still some haze spots .. captured pretty good on the camera , but you really have to "look" to see them .. and I think on top of the roof , no one would ever notice
overall , I'm pretty happy .. no more scratches , which were visable from far with the roof open , and also visable from looking inside up at the roof .. you no longer can see them , and the minimal haze , is not visable either
Did you use compounds when you did the final buff? I did the same thing with my side glass but i wet sanded then buffed with coarse, medium, and fine grit compound then finished it with wax. I couldnt see anything afterwords. In fact it made my other windows look like crap.
I did .. used brown , and green rouge' with a hi speed buffer .. then paste polish ..
I was going to try some ceridun oxide (sp) but just ran out of time
