Most perplexing problem EVER.
Chikokishi
General problem is that my 4runner sometimes does not start. Here are the details:
Only happens in fall and spring, do not have this problem in summer or winter.
Only happens occasionally, i never know when, or how often
Happens on full tank of gas, or nearly empty tank
Replaced starter, battery, and alternator.
The car "clicks" when i turn the key over. The gas pump turns on, the lights turn on, the starter does not spin.
If i release the key and try again it will *sometimes* start.
If i roll it down a hill she will clutch start perfectly.
If the engine does not start, i hill start, then turn the truck off immediately, it will start with no problem
Occasionally the battery is completely dead.
If the truck is not starting and i simply hold the key in the start position, withen 10-15 seconds the truck will start.
if i kick the truck, it will start.
if i walk in the house and come back outside 5 minutes later, it will start.
These are all true statements, and i have tried forever to diagnose what is causing the problem. I keep assuming a short somewhere as vibrations will usually cause it to start, but it only happens when its about 20-40 degrees day in and day out. Which.. shorts arnt temp dependant as far as i know. The charging system is fine, the grounding system is fine. The wires appear fine to me. Does anyone have a clue what this is?
Chiko
Chiko
No, this never happens ever.
:D
I never have that problem, either :D
First, what really clicks? The car? Starter relay? Circuit opening relay? Starter solenoid? If after spending so much money on replacement parts, and you still have the problem, I think it's time to replace your mechanic and understand:
How starting system works:
RAD4Runner's 1986 4Runner dlx Build-up - YotaTech Forums
Typical flaw with Toyota wiring:
and how to fix it:
RAD4Runner's 1986 4Runner dlx Build-up - Page 2 - YotaTech Forums
Best wishes and regards,
RAD
My shoulders and knees click, is there a mod for that?
*Really should report, obvious the member got hacked seeing as the wording's not even close in dialect??
OK, this isn't a deposition, LMK if you swore on a Bible though?
