Mounting Jerry Cans on Factory Roof Rack
I got it Online at eTrailer for 186. It's the Rhino mesh 49x37. That's about as cheap as I could find it with mounting hardware.
Sent from my iPhone using Tapatalk Pro
Thanks. After some poking around, I found it there too. Good price.
Here's my setup. I finally got around to putting it together. It's plenty strong and it holds my recovery gear.
Where did you get the 2 jerry can mount from?
Did you just use the mounting hardware it came with to place on your factory cross rails or did you some how mount this to the rails on the sides?
Another question, have you stood on top of this before? I am wondering becuase I'd like to, if I needed to, be able to go up there and take photos.
For most use cases you do not need a dedicated mounting solution for a gas can. Put it on the roof, put a cloth under it if you don’t want to scratch your roof paint, and tie it down securely.
The claim the Rotopax leak at the top of this thread is simply not accurate in my experience. I just drove 100+ mile through highways, trails all over Mendocino NF, and back home with a 3 gallon Rotopax strapped to my factory roof rack with no leak, no movement. Just get a $10 nylon tie down from Home Depot and do this:
Dropbox - 3F7E1B5D-497F-4FE6-9B98-7028F25238CA.JPG - Simplify your life
Jhunt
