Guys:
I tried the Mr. Clean product this weekend. It was not quite as good as they said. My truck was really, really dirty though, so I can't totally blame it on the the Mr. Clean Car Wash. The filter that is key to the unit only lasts three cleanings (a little weak). To use it, you put in the filter, add the cleaner and use the three position water selector. The first selection is just regular water to wash down the car with, then you turn it to soap which you soap up small sections of the car with. Then you scrub as usual. Then you rinse again with the regular water section, and then lastly you use selection 3 that pushes the water through the filter to remove impuities and makes the magic happen by making the water drain off in a sheet. The problem I had was that my washing cloth would get dirty and I didn't have any wash bucket to clean it off with and I had to switch that dial back and forth. It seemed to take much longer. I also think that the filter topping out with three washings in the starter unit and 10 washings in the full unit is a little weak. The soap was also a little weak in cleaning action and it still left water spots on the windows.
Let me know what you think.
Pete
