Muffler Pipe
shawn719
Odd question - so in advance I apologize to whomever.
Ok, now that's done.
What is the size of the tailpipe? Is it the diameter, circumference? I found chrome for sale but one of them has me confused
The reason I ask is because I want to order a Chrome cover, however, when checking around I see different sizes (but claim they fit the 2010 4Runner.) Seems odd to me (maybe for the 4 or 6 cyl?). There is even one that advertises a size 3 1/5 :confused: - is there a 1/5 measurement?? I seriously doubt it but, hey, I have been known to be wrong on certain occasions.
Here are two links with end pieces (one has the 1/5 measurment...)
TOYOTA 4RUNNER RAV4 4 7/10 X 3 1/5" EXHAUST MUFFLER TIP : eBay Motors (item 280461995871 end time Mar-08-10 22:31:14 PST)
TOYOTA 4RUNNER AVALON 5 7/10 X 3" EXHAUST MUFFLER TIP : eBay Motors (item 300394574649 end time Mar-08-10 20:33:10 PST)
Shawn
Here is the size both say 2.25 inlet WELD ON. These are generic tips.
* Vehicle Notes: Inlet-2.25", Outlet-4 7/10 X 3 1/5", Length-6.7", DOUBLE WALL, Rolled Tip, OVAL, Straight, SINGLE pipe, WELD ON Exhaust Tip
* Weight (lbs) approx: 2
* Vehicle Notes: Inlet-2.25", Outlet-5 7/10 X 3", Length-7", Resonated, DOUBLE WALL, Rolled Tip, OVAL, Slanted, SINGLE pipe, WELD ON Exhaust Tip
See ask and see that you miss the obvious answer - right on the page...
Have to get them welded on...hmmm
Ok - thanks for getting me stuck off stupid :roadkill:
I actually just installed that same tip yesterday, took about 10 min. It comes with 2 shims but I didn't need to use either of them.
Was there no welding required? Was it just a screw or clamp on?
Looking at options before ordering the $50.00 part.
S
No welding required. I used the shims and the tip is help in very solid. $50 well spent.
I set mine right before the exhaust pipe trims down in diameter, so the shim or shims weren't needed. It's a pretty heavy duty clamp, 5/8" wrench needed to tighten it. The end of my exhaust pipe flares out a bit, maybe other's don't so that why the shims have been needed.
I used the 3A racing 62-2417 screw on $35 at pep boys.
Yep, those will work great and are pretty nice and are made for pipes 3 inches or less. I just went and measured the outside diameter of the tailpipe and it is 2 3/4 outside diameter for the last 4-5 inches. So any aftermarket tip will work that is at least 2 3/4 inches.
Yes, nice and saves a couple bucks. Now have to find a PepBoys or go online (online it is...)
4RunnerTrail: the one I installed was made for the 2010 4Runner, bought it thru my dealership part's dept, part #PT932-89100
Thanks SR54Runner10! I just installed the 3A racing tip. Here are some pics.
<a href="http://s791.photobucket.com/albums/yy191/ttown311/?action=view&current=DSC_0127.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy191/ttown311/DSC_0127.jpg" border="0" alt="Photobucket"></a>
<a href="http://s791.photobucket.com/albums/yy191/ttown311/?action=view&current=DSC_0126.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy191/ttown311/DSC_0126.jpg" border="0" alt="Photobucket"></a>
Confused
So I measured end of tailpipe (as I notice it "flanged" out towards the end, last 4 0r so inches) and came up with approx 3" diameter - is this right?
Like to get a chrome cover but cannot locate one that bolts-on larger than the 2 3/4
:confused:
:confused:
Hey Shawn,
The exhaust pipe is 2 1/2" and flares to 2 3/4" the last 3-4 inches so you need a 2 3/4 " inlet or larger. Here is the one Ttown has on his .... Amazon.com: 3A Racing 62-2417 Stainless Exhaust Tip Slant Bolt-On Truck 3" Inlet X 9": Automotive
Just google " 3 inch exhaust tip" to find some more. You want the bolt on type.I'm looking for a black stainless one myself.
