multi mode transfer case question
The switch in question are the ones on top of the Transfer case. They Tell the ECU to engage the center diff.
The center locked indicator (4x4 Light) is the switch in the actuator assembly.
Yes, I know that. The CDL switch in the lone switch on the passenger side of the case mounted just below the shifter, correct? That sensor on a NON multi mode, standard j-shift case is the switch for the 4wd light. That switch is the one that I tested with my test light. It tests GOOD.
Is that correct?
Jhunt
