Murph's Build and Off Road Thread
ugamurph
Murph's TrailRunner
2001 Toyota 4Runner Limited 4WD - Locked
In the fall of 2012, I was inspired by [MENTION=67079]Fjatheart[/MENTION] to buy an off road capable rig. He had an FJ40 that he wheeled and an 01 4Runner that he was planning to build into a trail capable daily driver. After searching many FJ80s and 4Runners, I purchased this 2001 4Runner Limited on October 27, 2012. It was completely stock except for a TRD cat-back exhaust, K&N air intake, and an aftermarket Stereo/CD/DVD player with 12" subs and amps. I started modding it just days after I brought it home.
What it looked like the day I bought it:
Suspension:
Front - Old Man Emu 883 coils with OME 9004 shocks
Rear - OME 891 coils with Bilstein 5100 Tundra shocks (part# 24-100144)
SPC Light Racing UCAs
Toytec Diff Drop
Front & Rear swaybar removed (destroyed the driver's side mount twice, so I'm done with it!)
Armor:
Shrockworks Front Winch Bumper with Full Hoops
Stubbs Welding HD-SKO Sliders
Budbuilt Front Skid and Belly Pan Skid
Tires & Wheels:
265/75R16 Cooper Discoverer STT tires
Stock 16" Limited wheels (minus center caps)
Matching spare
Powertrain & Steering:
Stock 3.4L V6
Stock air intake with ISR Mod (Intake Silencer Removal)
Safari-LTD Steering Gear (11/06/2013)
4.30 gears
Rear e-locker (retrofit from a 1999)
Genuine Toyota Front Wheel Bearings
Genuine Toyota CV Boots on original Axles
Denso A/F sensor (10/31/12)
Plugs & Wires (11/4/12)
Denso Radiator (10/1/2013)
Exterior:
Snorkel
PIAA 510 fog lights in front bumper
4' Wilson CB antenna on front bumper
PlastiDip rear badges
Pinstripes by the trails of Tennessee
Sport hood installed (04/09/16)
Interior:
6th seat in cargo area (2nd gen front bucket w/ 3rd gen rear 3-pt seat belt) (Currently removed)
Cobra 19 DXVI installed in place of ashtray
Constant 12V plugs (console and rear)
Weathertech Floormats
BlueSea USB port
Fire Extinguisher
ARB Fridge/Freezer
Recovery Gear:
Superwinch Talon 9.5SR with Viking Amsteel Blue Synthetic Rope
Factor55 ProLink winch thimble
Superwinch roller fairlead
CO2 onboard air tank
Hi-Lift jack with roof rack mount
Various straps, shackles and other gear
Things to come:
Electric rear locker (axle housing and diff purchased (3/21/2016)
CBI (or homemade) rear bumper with Tire Carrier
Whitson Metal Works Roof Rack
Modular drawer system
Because I didn't actually keep up with a build thread since I bought the 4Runner, a lot of this will be a look back at what was done. It'll take some time for me to catch up. I'll be including not only mods and maintenance stuff, but there will be some off-roading pictures thrown in too.
I hope y'all enjoy.
Murph
I'd love to see pictures of the 6th seat. I'm looking for ideas. How did you bolt it in?
Those pictures and details will be up eventually. I should have started a build thread back in 2012 when I bought the T4R. Now I'm having to play catch up and it's going to take me some time. I'll try to get them up quickly.
Check back regularly for more updates.
_Murph_
The first mod was removing the running boards… "instant lift". Maybe not, but it did make it look better.
Before:
After:
On the drive home, the check engine light came on. After checking the codes, I determined that I needed to replace the pre-cat A/F ratio sensor. I ordered a Denso (part #234-9002) from Amazon for much cheaper than anywhere else. Of course, it was an easy plug and play install.
New sensor with gasket:
Old sensor:
New sensor installed:
The CEL codes also indicated a misfire on two of the cylinders.
This is why:
I installed new NGK plug wires and spark plugs.
Pretty Blue Wires:
I learned that PlastiDip wasn't just for tool handles. Dipped the emblems and tag surround
Finished:
I also PlastiDipped the grille:
**I need to redo the grille because I messed it up with a pressure washer. I got way too close with it.
I ordered 5 Cooper Discoverer STT tires (265/75R16) from Discount Tire. It's beginning to look like a true off-road vehicle.
(11/28/12)
The day after I bought my tires, I received my Old Man Emu 883/891 lift with OME 9004/60027 shocks from Toytec.
I paid the extra money to have Toytec assemble the front shocks/coils. I loved the "running man" hieroglyphics that they added. A special touch.
(11/29/12)
On 12/06/12, the UPS man brought these all the way from Susanville, CA.
Stubbs Welding HD-SKO sliders…
I took them out to the garage and "mocked them up".
Finally getting to the stuff everyone wants to see….
On 12/8/12, [MENTION=67079]Fjatheart[/MENTION] and I filled the day by installing the OME lifts on both of our 4Runners. That was a LONG day!
Before...
Front going on…
Rear going in:
The money shot…
And a couple of after lift poser shots…
(12/08/12)
Once my lift was on, it was time to get working on the sliders and having them installed. Over the next few days, I primed and painted them. One thing that I do regret is using the white "bare metal" primer. I found out quickly that when the topcoat gets scratched, the white shows through like a sore thumb.
These Stubbs HD-SKO sliders are great looking and very strong. I liked the fact that the legs came pre-welded. If I could go back and do it again, I would have had Richard weld in some gussets between the legs and mounting plates for a little extra rigidity and strength. Since I don't have a welder of my own, I had Essentially Off Road of Murfreesboro, TN weld them on.
Primer...
Paint...
Mounting by EOR…
(Installed 12/20/12)
I've got the same tires and I love them. Good looking 4runner. I'm ready to see the 6th seat as well
Thanks for the compliment. I've enjoyed these tires as well. They do great off road and they have good on road manners as well. I would've liked to have gone with a 285/75R16 or the 255/85R16, but I didn't want to deal with rubbing issues.
For Christmas of 2012 I got a Motorola 19 DXVI CB to be able to use on trail rides. I ordered an 18' Wilson antenna cable, a Wilson Flex-4 antenna and a FireStik stud mount. I built an antenna mount that attached under the left taillight. I eventually sold that mount and ordered an ODL mount which are no longer available.
I installed the CB in the dash in place of the ashtray. I created a how-to thread here… Install Cobra 19 CB in place of ashtray - 3rd Gen
That was a fun and useful install that created an OEM look for the CB.
Here is the mount that I built out of scrap metal that was in my garage.
(12/30/12 - 01/3/13)
First trail ride…
Derek [MENTION=88967]TNRunner99[/MENTION] and I went up to Windrock Park/Coal Creek OHV on a Saturday for a little trail ride. Since it was in early January, there was ice covering all of the water and waterfalls (not something we see a lot of down South). That ice was the cause of my first trail damage. I took another friend and my oldest son along with us and we had a great time. Here are some of the pictures (not the greatest quality)…
Beautiful Tennessee Sunrise on the way that morning…
A sheet of ice on top of one of the water holes gave me my first trail damage… busted both blinkers and smashed my "TBL" plate.
Instagram shot:
(01/05/13)
After about a month and a half of driving with the 4Runner lifted, I started smelling some grease coming from the front end.
I looked under the truck and found this on the driver's side inner fender and frame.
At first, I thought maybe it was coming from the brake line. But then I found this…
The inner CV boots were leaking on both sides. The driver's side was worst. I went ahead and rebooted both CV axles. It was a very time consuming and messy job, but not too difficult. The hardest part was finding that sweet spot to "pop" the axle out of the front differential.
Several items I bought from Lowe Toyota in Warner Robins, GA for the 4Runner. The new CV boots are in there somewhere.
Sorry… No pictures of the actual job being done. My hands were too greasy to handle the camera or iPhone.
The box in that last post contained a few other parts that I used for some small projects over the next couple of months.
I decided to give the 4Runner a retro OEM look with the FJ40 "4 wheel drive" badge.
I extended the rear diff breather…
Many people push the breather through the gasket around the gas filler neck. I chose to run it up behind but not through that gasket.
I cleaned and painted my drums and hubs to give the 4Runner a cleaner look…
And, since my hubs were clean and black, I decided to show them off by removing the center caps from my wheels. I like the utilitarian look of it.
I found this Uhaul tube style trailer hitch on Craigslist to replace my OEM hitch. It tucked up under the 4Runner a little better than the stock hitch offering a touch more of a departure angle. I ended up giving my OEM hitch to [MENTION=67079]Fjatheart[/MENTION]. He used it until he bought a replacement rear bumper with a built in hitch.
(Feb & March 2013)
The Old Man Emu lift that I installed on the 4Runner was the "Heavy" lift that included the 891 coils and 60027 shocks in the rear intended for 4Runners with extra weight in the back. Since I didn't have a heavier aftermarket bumper or a drawer system in the back, the ride was a little rough and jarring. Trying to remedy that problem, I tried a couple of different solutions. In March of 2013, I found a good deal on a set of front coils from a 1997 FJ80 to use on the rear of the 4runner. I purchased them and installed them keeping the OME 60027 shocks. The FJ80 coils were 7.5/8 wrap coils and gave at least 1-1/2" to 2" more lift than the OME 891 coils.
This picture shows the unloaded height difference between the LC80 coil and the OME 891.
The FJ80 coils lifted the rear even higher and created a lot of rake with the OME 883s in the front.
I rode around with this setup for a couple of weeks. At first, I didn't mind the rake. But, after awhile I decided I would prefer it be closer to level. Obviously the FJ80 coils offered a ton of flex, but the ride was still pretty rough. After more research and learning more and more about how coils and shocks work, I determined that the harsh ride wasn't because of the coils. I decided to try a different set of shocks. I ordered some Bilstein 5100 shocks that were built for the rear of a Tundra with 0 - 2" of lift. Bilstein part #24-100144. These were a near direct bolt-on for the 4Runner. The shocks came with a vulcanized bushing that did not fit the lower shock mount of the 4R. I pressed out the vulcanized bushing and pressed in a Daystar bushing that would fit the 4R's lower mount.
The new shocks…
and installed…
Since I was starting to not like the rake of the FJ80 coils, I went ahead and re-installed the OME 891s.
I have kept this setup since then and have been pleased with the ride quality. Whenever I end up putting a replacement rear bumper/tire carrier on, I will probably want to go back to a heavier shock such as the OME 60027.
(03/22/13)
The next trail ride was coming up, so I picked up a couple of "just in case" accessories.
Recovery…
and Safety…
