My 1990 build thread
Ok ... so ... car starts but runs rough at startup WHEN it starts up. We have to use carb cleaner to get it started.
I know the blue sensor is a vacuum line for the 'choke' but I've also been reading that the injectors can sometimes get clogged and need replacement?
Once it's on, it runs fine but it's a PAIN to get started even if it hasn't been sitting that long. That, or the timing is slightly off? What do you all think? Cold start injector? I just want to be done already - soooooo close.
Took the cat off, it looked fairly new but I decided to check anyway due to the initial head gasket failure from the previous owner. I could see through it just as well as the new one but I replaced it anyway.
As for the starting issue, we've noticed some considerable vacuum line leakage and the timing sounds like it's off, way off. There is a major lack of power (can't accelerate over 15mph) and that's when we can get it started with starting fluid.
Thoughts?
We have spark, no fuel to the upper plenum.
Just replaced the fuel filter but there is NO gas in the tank now.
Here is my list of items to check ...
GAS
12V to fuel pump (should be ok, it never shut off when it did run)
Check fuel pressure regulator
check fuel damper
Brother in law replaced this little bastard ...
Still a few things I can think of but the list is getting shorter.
Has a half tank of gas ..
Need to check that we have 12V to fuel pump - should be, it doesn't die when running
Change blue sensor - done
Check fuel pressure regulator (gas smell) - OK
Check fuel damper - OK
Fuel pressure should be between 38-44 psi - need to check
No fuel to upper plenum, no start
For the record, there were 2, 90 degree bends in the fuel line near the gas tank and that's why it wasn't getting fuel. :sniper:
Brother in law found that and saved me $150 for the fuel filter and strainer.
The firing order was wrong and that's why we were getting a knocking sound right above idle. Here's a video of it running now, beautifully ...
New engine, new everything pretty much.
New speakers got here today ... DIDN'T realize the rear ones were such a pain to get to ... And I bought 6.5"'s vs whatever goes in there :doh:
^^^Yup! I just cooked one of the speakers in the back of mine as well. After looking at the panel and such it sucks. If I didnt care about the panel as much I would just use a cut-off wheel and cut out the square that goes over the speaker and just clear silicone it back on after replacing the speaker...but I care so...
Good Luck!
