My 1999 suspension is driving me crazy
wdhigh
I got a 99 limited 4x4 with 140k. If you look at my 4runner it looks like so many others with a saggy rear. Even my hitch ball and receiver carry basket have the rear lean while installed.
After reading topic after topic on rear sag and how great 99 springs are I decided to actually go measure mine. Drivers side is only 1/2" low in rear. Passenger side is just over 1" low in rear. Also noticed my front driver side and passenger side seem to not be level.
For starters, how do I level it side to side in the front?
Second, does anyone know if the rear is supposed to be level with front or have any rake?
I have been meaning to order the daystar 1.5" spacers for a while now, but am now scared to put them in due to possibly having to much rear lift and looking stupid!
Another possiblity is a complete small lift kit front and rear. My worry is still having rear droop after install is complete.
Thanks in advance for any info!!!
Also have read alot about "PP 1" lift" What or who is PP?
I'd suggest (if you're not too partial on a lift) is that you replace your springs with the tall 99 springs. My 99 was not equipped with them (lame!!) so instead of a lift and all that, I'm going with new 99 springs.
I was talking to Brandon (StickFigure) who recently did his, hopefully he will chime in. Seeing our 4Runners parked alongside each other showed his was way taller, keep in mind I have shorter springs and sag all around.
I'll be doing it when I get new shocks.
He also has 265/70/17s IIRC, so that too brought his truck to a mild and desirable height. Those are one size larger than my tires, a 33" tire I think
Lopsided
I had the same issue with my 1999 4Runner, V6, 4WD, SR5 recently. It drives fine but the lopsided-ness ( if there's such a word ) keeps me awake all night. A local independent mechanic quoted me $490 for both front and back springs and it's back to its normal stance again. I do not have the inclination to lift mine, so I can't contribute to your LIFT question.
All the best.
Cheers,
Walter, Las Vegas
