My 2002 is turning 60,000 soon, what maintenance?
ScottDetroit
Hi everyone
I haven't posted in awhile. The new firewall at work didn't allow me to. I finally bought my own computer last week!!! My question is, my 2002 4Runner in flipping 60,000 soon. I have not taken it to the shop since I bought it in 2003, when it had only 5000 miles. It's running great, but what do I need to have done or look out for soon as far as maintenance is concerned? I want to keep my truck in tip top shape and want to do whats needed to keep it running great.
Thanks for any help or info,
ScottDetroit
2002 4Runner
60,000 Miles - 48 Months
<< BACK - INTERVALS - NEXT >>
Replace engine oil and oil filter
Replace engine air filter
Replace engine coolant
Lubricate propeller shaft (4WD)
Replace non-platinum spark plugs 3
Re-torque propeller shaft bolt
Rotate tires
Inspect the following:
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs
Drive belts 4
Drive shaft boots (4WD)
Engine valve clearance
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads
Inspect nuts and bolts on chassis and body
Towing a Trailer or Using a Camper or Car-Top Carrier
Replace front differential oil
Replace rear differential oil, including limited-slip
Replace transfer case oil (4WD)
Replace transmission fluid or oil
Applicable Footnotes:
3) Required under the terms of the Emission Control Warranty.
4) Initial inspection at 60,000 miles. Inspect every 15,000 miles thereafter.
