My 4runner is sluggish poor, plz help
pdzepeda
Maint and Engine light came on the other day to include the vsc trac light, pulled the code at autozone and tightened the fuel cap, reset the codes after and ran fine for a day. Had oil changed and maint light turned off, Then it started bogging down on acceleration and was very sluggish from there on, every so often when i get on the pedal it starts off slow then seems to grab hold then shoots off like normal? it will run fine for a bit then return to bogging down and running sluggish again. There are no more codes registering ???? wat the heck, could it be a def fuel pump or bad cat. seems like a fuel restriction but everything seems to be in good working order. Any suggestions please??? Thanks To be honest it seems as if something is clogged.
thx!!
I had a similar issue with my last 4Runner. Took it to a shop, and turned out to be a bad cat converter. If I remember right, it was a fairly cheap fix. Good luck, man.
delislerebecca
