My 4runner seems very slow
My previous E90 330i sport pckg was fast, BUT slower than my
4runner. With the crappy roads in my town, I was always having
To slow down avoiding pot holes. Specially since it did not have a spare tire thanks to those run flats which eventually got replaced with regular tires to
imrove the jarring ride (once again crappy roads).
Some cars adjust to your driving behavior and after some
miles/time they will calibrate the shift points. When I drove the t4r out of the lot,
I had the same thoughts as the OP. after a couple of months i had no
More complaints. Same thing would happen with
My wife's ML350 after it got serviced, it seemed as if they did a software
Upgrade or something. It would never drive the same
as before bringing it in.
The Trail has a wind brake up front to assist Crawl Control :boink:
The Limited is faster since the hood is more aerodynamic and the leather seats are slippery quick :)
Slow and steady wins the race.
What im learning is that the ecu enters a certain mode based on your initial level of aggressiveness with the throttle. If you are lazy with the throttle acceleration is gonna be tepid. If you go deeper with the throttle initially, acceleration improves significantly.
What I really like about the new runner compared to the 05 is the size, perfect size for my needs. Also, the new dash / interior is much improved, feature wise as well as materials quality. The new shape (to me) is more masculine. Right now in mixed driving im averaging 19.3 so thats pretty good.
Thinking of doing some light mods. Maybe some led interior lights, a more aggressive tire &rim combo, spidertrax spacers, and window tint.
I have a 2014 TE and just rolled over 2000 miles. The engine is very tight and you should see it starting to loosen up. Also per Toyota, don't run it in sport mode until you exceed 1000 miles for break-in. I too had an 05 V6. Shifting is definitely softer then the 05 and it goes to 5th at 38 MPH under light throttle. I can tell you this, the 14 is definitely faster and you have to learn a different throttle response. I dumped mine yesterday and it does really jump, much harder then the 05. MPH is on par with the 05 seeing avg at 17.5 on winter fuel, with very cold temps and richer mixes at start.
Where did you see that? I'm at about 700 miles on mine and I've been using the sport mode to vary the revs and hold it at something higher than 2k (which is about as high as the normal mode will let it go as best I can tell),but still below about 4k. As I learned it, it was more important to vary the revs over the first 1000 miles than anything else, but should I be letting it stretch out more slowly?
(Nevermind the fact that the other 98% of T4R drivers pay no attention to the break-in process - we'll stress over it for our own edification apparently).
ROFLMAOPM, baaahhaha! :pound::thumb3:
I heard if you attach 3 cans of starting fluid and a lit propane torch to said wind brake it behaves like a scramjet capable of breaking mach
actually i am glad its has a slower demeaner. coming from 10 subaru legacy that got me into too much trouble, i was glad to move into the 4runner. it has slowed down my spirited driving alot and my road rage has almost completely gone away since i am now the slow poke and dont care anymore who i piss off.
Is that due more to the 4Runner or the meds? :D
The one thing i find "surprising" or perhaps alarming is that having been used to the sedate speed and sound of the 4runner, I occasionally floor the accelerator, it gives a race car or high-pitched roar. is this normal ?
I'm assuming your question is serious despite the slightly sarcastic overtones some might think this thread carries. Yes, this is both normal and surprising. That is one thing that drives some people nuts about the CC (sorry philsey) in hilly situations.
Manual under Break-In. With today's machining processes, most likely not an issue. However, moving parts do require some break-in time without over-revving engine
Trade in the 4runner for a Porsche cayenne if you want more power. Apparently that is what you thought you were buying to begin with.
It's got plenty of power (for a V6) but it's higher up the tach and programmed for mpg eg early upshifts, sluggish throttle response.
This! Coming from a V6 '08, the aggressive early upshifts are what bother me the most. My '08 was actually pretty peppy and the shift strategy was rather nice. No so on my new one.
Yep. I also heard that when they dyno the engines after assembly, they put the poorest performing ones into 4Runners with boring colors like Super White.
Even with my fast color black, the slowness has caused me to only go 192,000 miles instead of 384,000.
Tx470
