Pinging Issue totally resolved!
jross20
First off I want to apologize for my long absence for a few weeks... I don't know if I've shared it with anyone but my grandfather was diagnosed with ALS and it has been incredibly hard on us. Please keep him in you prayers if you can.
Full story below, but for those who just want the results, I added a TLDR at the bottom.
So, probably for over 6 months now I've been having to buy premium gasoline, because anything less would cause the engine to ping horribly on the slightest bit of an incline. Originally when it first became bad, it was actually so bad sounding that I literally thought the engine (V6) had exploded or something.
I had changed the spark plugs, at the timing check, had two mechanics check it out all to no avail. It wasn't running lean, if anything it was rich. Just made no sense...
Stepping back in time for a minute... Slowly, over the course of about a year or two, which of course was prior to the pinging, I had gone from averaging about 19 to 19.5 mpg for my typical work week drive, down to 18.5 to 19, then 18 to 18.5, then 17.5 to 18, then 17 to 17.5, all the way day to 16, etc... You get the point. Power was also, in my opinion, very lacking and felt like she always bogged down. All the time, not a single code, nothing at all that made any kind of sense that I could figure out...
So anyway, now fast forward to about a month ago, a gearhead friend at work who likes messing around on BMWs and Mercedes said "if it seems hot for no reason and doesn't want to accelerate, you should probably replace the catalytic converter at that age". I always been curious if this could be a possibility, but I presumed it would have set off a code or been more obvious.
After that, I went to a small, somewhat sketchy muffler shop, where the lead guy messed around with it for a bit and told me that while there were no codes he said it was excessively hot in his opinion.
At that point, I said "f it", I'll replace it and see what happens.
Well about $800 later, I'm driving around testing the new one and as far as I can tell it made literally no difference to the temps at all... Not only that, it's way louder than the stock. I was pretty frustrated and told myself that I would just get the other one put back on and try to sell off the other one to recover some of the money...
Well, this is one of those times where it paid off to be lazy. So one of the first things that I immediately noticed is that two fill ups later, My gas mileage had completely tanked. The first whole tank on the new cat was like 15 mpg. "Damn, my poor truck" I said to myself... Haha.
Now for the next part, I honestly cannot say what made me think to try changing to non-premium, but I decided to try it. The next tank I went down to mid-grade, all was well. So the next tank after that I went down to regular, all was well. No at this point I was still skeptical, so I kept doing regular gas for the next few tanks, and sure enough the pinging was totally gone. They're always certain spots, small hills, where if I purposely tried I could always get her to ping but even in these areas she was silent now.
So here's the next thing, ever since then my mileage has slowly but surely started to come back up. Again, I pretty much always drive the same exact route to work. Now the only thing that's weird is that while it's consistently up now, it does still fluctuate a bit wildly. So like I had three fill ups in a row where I'm getting 18.5, and then the next one is like 16 mpg. Then, the next one is 18 again.
I presume that all of this has to do with the ECU relearning with the new cat? But the weirdest thing is that I really don't understand why the new cat fixed the pinging. Mainly because I presumed that if the air fuel mixture was wrong that it would be lean, not rich. And when I say Rich, I mean long-term fuel trim would always be like plus 5%. So not crazy or anything.
TL;DR:
I replaced my catalytic converter trying to solve the heat problem, inadvertently fixed the pinging problem. Gas mileage greatly improved but it's still a bit volatile. For those who are curious, I got one of those MagnaFlow direct fit cats for about 600 and some change.
The clogged cat was putting excess back pressure on the engine and those hot gasses were pre igniting the air fuel mixture.
It could be clogged from carbon or from the honeycomb melting. You should be able to look inside and see.
So it could do that without effecting the temperature of the engine? That is wild.
All right so I got the old one and lugged in to check it out. On the straight side, the output, it looks pretty uniform to me. I would need like a camera or something to look in the input side. Also, now that I'm looking at this it looks like one of the '02 sensor gaskets was missed... If it cools down at all today I'll have to get under there and see if it is indeed missing a gasket.
I wonder if it was just a fuel issue all along? Maybe shine a light to see if the old converter was actually blocked some? You can back pressure test while on the car.
I have new converters in the garage to install. I really need to get the bs cleared out of the way from the move so I can actually use the garage....lol.
Another possible issue around premium fuels, and it's very location dependent mind you, is that much of the time the premium fuel is lower in octane than the lower grades as the lower grades tend to get consumed much much faster, at least here in the Intermountain west. Years ago a guy I know had a bunch of fuel tested. The results we're surprising. Our goal was around finding the best fuels for high compression snowmobiles.
If you lived in an area where lots of premium gets sold, your probably fine. Here though.... good luck.
Glad you got it fixed. That kind of thing can be pretty frustrating when chasing ghosts.
Oh man, tell me about it. I mean in general bad pinging like that is scary anyway, but then when it just seems bizarre and doesn't make any sense it really makes you feel like something is really wrong.
And you know it just really sucked having to get premium and then just driving it knowing that something was wrong, but that I had no idea what it was.
You know it's so simple, but I never thought about using a flashlight. I'll give that a try when I get home.
And that's pretty interesting about the premium fuel situation. But I mean if I put in premium, she was basically silent, but even mid-grade would cause her to pee somewhat if I didn't always gear down heavily.
Our fuel is junk. The refining I believe changed when they added ethonal to the mix.
It's a shame the fuel is so. Too Bad you have to run premium. :(
Oh no she's good now. With the new catalytic converter she doesn't ping at all with regular grade. Although I do run non-ethanol.
Oh no she's good now. With the new catalytic converter she doesn't hang at all with regular grade. Although I do run non-ethanol.
Oh I am glad your fixed. I just saying the bad fuel quality caused it. It's a shame...
All right guys, I stuck a flashlight on both ends and no matter what I do I cannot see a single lick of light through the other side.
Should I be able to see any light at all? While the exit side looks clean to me, or as clean as it can probably be, I can't see into the other side without cutting the pipe.
But like I said, I shined a flashlight on both ends and I can't see anything on the other side. I even tried it with the lights off in the dark just to see if there was any bit of light at all coming into the front...nothing.
I believe based on this and the result of the pinging being fixed, we can conclude that the old one was bad.
anyone try that catakleen stuff, however it is spelled...snake oil you put in your gas.....does that stuff work ?
I haven't, but I guess if we wanted to do an experiment I could get something like that and pour it in to see if it cleans anything out.
Mostly if the cat webbing is not all melted to a blob. Or just gone it's from running too rich. Newer vehicles will tell you that cat is burned out by giving you a too fast airflow error. The o2 sensors can tell the cat isn't functioning properly or gone.
What lead up to this? Like you put high flow injectors in and the cat couldn't compensate.
Was it buring coolant for a while?
Burning large amounts of oi?
If not, I am wondering if this is the long term effect running ethonal in the gas and thus damaging them.
Just a thought and can be nothing.
As something plugged that cat up.. :(
I doubt it’s ethanol. Or my fleet of vehicles would all require them.
Burning oil, running rich. Yep.
Driving with a flashing check engine light. Most defiantly yes.
Antifreeze. Not really or mine once again would be shot and at 299,890 miles it’s doing fine and sets the cat readiness monitor on my first drive cycle test.
Your probably correct. I am just trying to brainstorm as the possibles for melting down the cat. :-)
The usual culprit is a lack of service around spark plugs and older vehicles. With the introduction of widespread fuel injection somehow people forgot to maintain their cars I guess. I've ran into this maybe a half dozen times or so with older gasoline rigs of various makes. Especially true with Subaru and Toyota or any machine that utilizes waste spark technology. Not as much of an issue around GM as they went to high energy ignitions and high quality delco spark plugs pretty early on.
This current 99 4Runner that I have has the same issue. Bought it cheap because I didn't run right, and it really needed was a tuneup. The plugs were worn out beyond belief. The problem with that is that you can create an incomplete burn situation, and it doesn't take a whole lot of extra fuel load to take the converters beyond their threshold and cook them.
Any easy test to see if your converters are fried is if the downstream pipe temperature is higher than the upstream inlet pipe temperature using an infrared thermometer.
Assuming you're only looking through one converter, and your vision is not obstructed by a pipe bend, you should be able to observe light passing through some what.
If your trying to look through both converter's at the same time I doubt you'll see anything.
I personally haven't had any success with it the two vehicles i've tried it in. A friend of mine that turned me onto the product is about 3 for 5 for success on it.
I think if it will work, it's certainly a cheap product. I have a feeling it has to do with the fact that if the metals inside the converter have been damaged due to excessive heat, it probably won't work. If it's just dirty or partially clogged due to contaminants, but hasn't been overheated, it may work.
It's worth a shot for sure.
Heck Tetanus 1 actually had an spark plug electrode snap off and parts of it are still in the piston ( Before i owned it) The PO thought he was loosing rod or something. When he caused it by not changing the plugs. I see wear on the plugs are gone... You know how long that would take to cause that. Probably the original plugs in 215K...lol
Bunkstaff
