I grabbed all the part numbers I use (or plan on using) for maintenance along with their current costs (except for a couple: where we do a hack like the cabin filter or shop at Walmart for oil) for my 2008 V8 4Runner Limited.
If there's a wrong P/N -- please let me know!
Oh, forgive the formatting. Can't straight copy->paste from excel. Had to drop it to a CSV and then modified it via a perl script using a printf (lol) and then pasted it via a CODE block.
As for the coolant: Can't ship due to it being "hazardous materials"
Code:
Toyota Interval Part Number Qty Note Partznet (ea.)
Oil 5K N/A 1 0W-30 @ Walmart $24.50
Oil Filter 5K 90915-YZZD3 1 $4.00
Oil Drain Gasket 5K 90430-12031 1 $0.84
Plug: Drain N/A 90341-12012 0 $3.23
Air Filter 12K CA8918 / A35305 1 Fram / Purolator
Cabin Filter 12K CF9846 / C35516 1 Fram / Purolator
Front Diff: Gasket 100K 90430-24003 2 $1.27
Plug: Drain N/A 90341-24014 0 $6.73
Plug: Fill N/A 90341-18032 0 $4.38
Plug: Breather N/A 90930-03136 0 $2.98
Transfer Case: Gasket 100K 90430-18008 2 $1.08
Plug: Drain N/A 90341-18006 0 $3.06
Plug: Fill N/A 90341-18006 0 $3.06
Plug: Breather N/A 90930-03172 0 $1.53
Rear Diff: Gasket 100K 12157-10010 2 $0.87
Plug: Drain N/A 90341-18057 0 $7.25
Plug: Breather N/A 90930-03031 0 $6.33
Spark Plugs 100k 90919-01210 8 $7.67
Timing Belt 100K 13568-09070 1 $40.60
Idler Sub Assembly (Left/Idler Pulley) 100K 13503-0F010 1 $65.88
Tensioner 100K 13540-50030 1 $41.54
Idler Sub Assembly (Right/Tensioner Pulley) 100K 13505-0F010 1 $65.62
Water Pump 100K 16100-09201 1 $105.87
Gasket: Water Pump 100K 16271-50010 1 $4.43
Cooling System: RTV 100K 00295-00103 1 $10.23
Cooling System: O-Ring #2 100K 96761-24019 1 $2.43
Cooling System: O-Ring 100K 96761-35035 1 $2.62
Thermostat 100K 90916-03138 1 $25.52
Thermostat Gasket 100K 16346-50010 1 $3.23
Radiator Cap 100K 16401-6A140 1 $10.23
"Hose: Lower (Hose, Radiator #2)" 100K 16572-50190 1 $14.87
"Hose: Upper (Hose, Radiator #1)" 100K 16571-50200 1 $13.45
Serpentine Belt 100K 90916-02586 1 $38.41
Coolant 100K 00272-SLLC2 3 $15.42
Cam Seal 180K 90311-71002 2 $7.38
Crank Seal 180K 90311-A0001 1 $7.40
