My parts number list!
Merle
I grabbed all the part numbers I use (or plan on using) for maintenance along with their current costs (except for a couple: where we do a hack like the cabin filter or shop at Walmart for oil) for my 2008 V8 4Runner Limited.
If there's a wrong P/N -- please let me know!
Code:
Toyota                                    	Interval	Part Number    	Qty 	Note                  	Partznet (ea.)
Oil                                       	5K      	N/A            	1   	0W-30 @ Walmart       	 $24.50
Oil Filter                                	5K      	90915-YZZD3    	1   	                      	 $4.00
Oil Drain Gasket                          	5K      	90430-12031    	1   	                      	 $0.84
  Plug:  Drain                              	N/A     	90341-12012    	0   	                      	 $3.23
Air Filter                                	12K     	CA8918 / A35305	1   	Fram / Purolator
Cabin Filter                              	12K     	CF9846 / C35516	1   	Fram / Purolator
Front Diff: Gasket                        	100K    	90430-24003    	2   	                      	 $1.27
  Plug:  Drain                              	N/A     	90341-24014    	0   	                      	 $6.73
  Plug:  Fill                               	N/A     	90341-18032    	0   	                      	 $4.38
  Plug:  Breather                           	N/A     	90930-03136    	0   	                      	 $2.98
Transfer Case: Gasket                     	100K    	90430-18008    	2   	                      	 $1.08
  Plug:  Drain                              	N/A     	90341-18006    	0   	                      	 $3.06
  Plug:  Fill                               	N/A     	90341-18006    	0   	                      	 $3.06
  Plug:  Breather                           	N/A     	90930-03172    	0   	                      	 $1.53
Rear Diff: Gasket                         	100K    	12157-10010    	2   	                      	 $0.87
  Plug:  Drain                              	N/A     	90341-18057    	0   	                      	 $7.25
  Plug:  Breather                           	N/A     	90930-03031    	0   	                      	 $6.33
Spark Plugs                               	100k    	90919-01210    	8   	                      	 $7.67
Timing Belt                               	100K    	13568-09070    	1   	                      	 $40.60
  Idler Sub Assembly (Left/Idler Pulley)    	100K    	13503-0F010    	1   	                      	 $65.88
  Tensioner                                 	100K    	13540-50030    	1   	                      	 $41.54
  Idler Sub Assembly (Right/Tensioner Pulley)	100K    	13505-0F010    	1   	                      	 $65.62
Water Pump                              	100K    	16100-09201 	1   	                      	 $105.87
Gasket:  Water Pump                       	100K    	16271-50010    	1   	                      	 $4.43
  Cooling System:  RTV                      	100K    	00295-00103    	1   	                      	 $10.23
  Cooling System: O-Ring #2                 	100K    	96761-24019    	1   	                      	 $2.43
  Cooling System: O-Ring                    	100K    	96761-35035    	1   	                      	 $2.62
Thermostat                                	100K    	90916-03138    	1   	                      	 $25.52
  Thermostat Gasket                         	100K    	16346-50010    	1   	                      	 $3.23
Radiator Cap                                   	100K    	16401-6A140    	1   	                      	 $10.23
  "Hose:  Lower (Hose, Radiator #2)"        	100K    	16572-50190    	1   	                      	 $14.87
  "Hose:  Upper (Hose, Radiator #1)"        	100K    	16571-50200    	1   	                      	 $13.45
Serpentine Belt                           	100K    	90916-02586    	1   	                      	 $38.41
Coolant                                   	100K    	00272-SLLC2    	3   	                      	 $15.42
Cam Seal                                  	180K    	90311-71002    	2   	                      	 $7.38
Crank Seal                                	180K    	90311-A0001    	1   	                         $7.40
Oh, forgive the formatting. Can't straight copy->paste from excel. Had to drop it to a CSV and then modified it via a perl script using a printf (lol) and then pasted it via a CODE block.
As for the coolant: Can't ship due to it being "hazardous materials"
And from the nice guy at Partznet (Aaron Morgan @ Conciello), have an update for few numbers:
There are just a few part number corrections I have for you. Here they are:
Crank seal: 90311-A0001
Cam seaL: 90311-71002 x2
Water pump: 16100-09201
All of the other part numbers seem to be correct for a 4Runner with the VIN# of JTEBT17R18K002894.
As for the coolant, we can not ship that as it is considered a hazardous material and we can not ship such materials.
erinobr2000
