My take on a tire carrier
midcoma
Member
I decided to build a tire carrier for my wife's daily driver. I'll give a brief explanation of my thought process, followed by a lot of pictures. I think [MENTION=17736]AddictedOffroad[/MENTION] might be interested in this. Sort of like your lambo carrier, but opposite.
As stated, this is my wife's daily driver. I removed the stock gas tank and replaced it with a Ford gas tank that is located where the factory spare tire use to be. Since then, we haven't had a spare tire on the vehicle. I needed a design that would work for my wife. Ideally, she should be able to complete a tire change on her own if I'm not around to help. So here's my take on some designs.
Swing out.
Too bulky. She would get frustrated with having to open it completely every time she wanted to lift the rear hatch. If anyone ever parked behind her, forget getting into the back. But the main concern is that if she ever had to change the tire, she would have to remove one from head/chest level, then lift the damaged one back up there.
Swing down.
Easy to remove and remount the tire once lowered. Would have the same problem as a swing out if someone parked behind you. Would also have to either lean over the tire to load/unload things from the back or do it from the side. She would also get a good deadlift in every time she had to lift the tire.
Even if she pulled forward into a parking spot in a parking lot, the swing out/down would open into the driving lane. That isn't something I wanted her to have to worry about.
Lambo.
I really liked this design, especially with the gas strut. Easy to lift, doesn't take as much space to open, controlled lowering. The only down side I saw to this design was that she would still have to remove/remount a tire from head/chest height.
So I decided on a swing down design. I got the idea from the "KnuckleBone" tire carrier produced by Detours USA found here.
I wanted something that mounted to the stock trailer hitch, without using the hitch receiver. I did not want the license plate to mount in the center of the spare tire because I don't want to remove it every time the spare tire comes off. I also didn't want to make the license plate easy enough to remove that it would be easy to steal. I know that weight distribution is already heavy to the driver side, but I wanted the tire offset to the driver side so that the right lane could be viewed through the rear window for merging.
So here's pictures.
This was the design/build stage. The most difficult part was getting the geometry correct so that the tire cleared the hatch when lowered.
This was the initial mock-up for the gas strut.
This is all the parts after paint.
The idea for the gas strut came after initial test fitting. I installed the tire carrier, mounted a tire, then had my wife try to lift it. She was seriously struggling. The first strut I tried helped, but she was still having to put in some serious effort. The strut I settled on is part #6465K6 from McMasterCarr. It has a max extension force of 269lbs and a max compression force of 383lbs. It's also adjustable. It comes pressurized to max force and can be reduced. I found the max force to suit this design well. I can lift it with one hand and she can fairly easy manage it with two. It controls the downward motion of the tire, only needing slight hand pressure to control it from waist down. If you try to lift the tire too quickly, the strut will fight you. You need to lift it at the strut's pace to allow it to adjust. Overall it's a very controlled, relatively easy motion.
The addition of the strut added one more challenge. If the strut is adjusted for the weight of the tire, when you remove the tire the strut will push the mount back up. This isn't a violent motion because the strut controls it, but I want the tire removed and remounted from as close to the ground as possible. That's why the tabs were welded to the right side of the pivot point. When the tire is lowered, the pin gets inserted into the upper holes to fix the assembly in place. Then the tire can be removed without the bar raising. The fixed position also holds the tire about 1.5" above the ground so you don't have to slide the tire across the pavement to get it removed or mounted.
Here's pictures of the assembled tire carrier without a tire.
This is with the tire mounted, locked in the lower position.
Hatch clearance when locked in the lower position.
The tire will reach the ground if not pinned. This is how it will be used on a daily basis when the spare isn't being removed.
Locked in the up position.
Here's how I did the wiring for the license plate light. It's a 24" strip led, slightly trimmed. I welded 2, 1/4-20 studs behind the plate bracket for metal straps. The ground wire has a ring terminal that grounds on one of those studs. The positive wire was spliced into the "hot" taillight wire for the trailer wiring.
My tires are 285/75R16 Michelin LTX M/S2. They don't have large, aggressive tread, but they're large and rather heavy. Between the pivoting bar and the fixed base are oil impregnated brass washers to reduce friction. The majority of the assembly is .120" wall, 2"x2" square tube. The tire plate and all the gussets are 1/4" plate. The pivot bolt is a grade 8, 3.5"x9/16" bolt. The pin is a custom pin I made, but a standard 5/8" hitch pin will work also. Both holes for the bolt and the pin are sleeved with tube to prevent crushing the square tube or rusting from water getting inside. The gas strut has about 1/2" of preload when in the raised position, so it's constantly pushing the assembly closed. I placed adhesive felt on one half of the angled bar to take up any extra slop and prevent paint wear. The entire assembly is very rigid. I haven't noticed any bouncing, shifting, rattling, vibrating, rubbing, or moving while driving.
The best part is that it's easy enough for my wife to operate and it stays out of the way when lowered.
Nice job on the design and fab work! The brackets, bracing, and welding look good! Just one thing, how thick is the hitch? I just worry about the carrier tearing a hole in the hitch after carrying the weight of your spare for a couple thousand miles. You might have to plate the outside of the hitch to keep it from tearing.
After seeing your design, I remembered a design that I had thought of a while back that is similar to what you were designing this around. I didn't like that most tire swings, swing way out and can be a hassle in tight situations or on an off camber situation with all the weight wanting to swing open or closed. And the problem with the vertical swing up (lambo style) carriers are just as much of a hassle for someone that doesn't have the strength to lift the tire. So I was thinking about having the spindle mounted at a 45 degree angle so that it lifts up and out and it is still somewhat easy to lift and wont swing out very far when opened. With an added gas strut like you did to assist is raising an lowering it, it may actually be easy for the wife to operate.
You got me thinking if I should actually try this idea now.
I love how this looks and functionality is perfect. I would love to get one like this for my truck. How much to make one that would easily fit a 35x12.50R17 Wrangler MT/R and if I dropped of my trailer hitch?
thadjay
