My torque wrwnch detected my error being made on the Eng oil drain plug.
jow
My torque wrwnch detected my error being made on the Eng oil drain plug. I pull the plug (looking initially), moved back for the drain and wiped clean. I replaced the plug with a new gasket and ratchet tightened to my sealing feel. Then I checked for 25 Ft Lbs with my torque wrench. The torque wrench and my feel are usually close but when I saw I was over ¼ turn off I knew something was wrong. I pulled the plug to find the old seal (both blue etc on aluminum looking sandwich). Without the Old seal, my tightening to feel and checking was in specs. Plus, I check my snapping (micro torque wrench with my pointing to scale t/w.
The truck should be happy for 6 mo due to my Ext Warr oil change at 5,000 or 6 mo. I will change at 3,000 mi or yearly after the warr vs the approx 2,000 I have averaged or less. Even at 6 mo you can see it is not a total waste (Castrol 5-30 Synthetic Blend) on the 07, SR5, V6, 2WD and 52,000 mi, (purchased at 43,000 mi, 9,000 mi in 2 yrs this month).
is this the "post here when you are drunk" thread?
or
am i the only one NOT understanding what the hell just happened?
lol.. He is just happy to report that he found his own error which could have cost him if the oil would have seeped out.
I hope a typing mistake caused me to get roasted. Versus me sharing in a rush you can make little mistakes. A check and balance system or double checking can help catch many mistakes. I hope the men that roasted me, do change their own oil, as my 50+ years vs faulting my tip. Plus, I'll admit you need to wear your glasses if needed.
Have Fun Wrenching!
I don't see what you guys have an issue with, he stated quite clearly that "I pulled the plug to find the old seal (both blue etc on aluminum looking sandwich)"
Maybe it's become against forum rules to post that you made a mistake and realized it before it was a problem. My guess is there are a bunch of cranky people here today.
The double gasket affected getting a good reading after the good torque feel with just a ratchet. I have learned a lot from mistakes of others and appreciate the tips. Plus, I have learned STUFF will happen without a reason.
Double checking your work can catch errors that can easily be looked over. My worst experiences have been on cars in warranty that required dealers to repair. In one case 5 ext bolts were broken off during an engine rebuild. We settled with a new engine installed. In another they had to pay me for labor on tracing a short due to a factory error.
Have Some Fun vs Stuff !!
No, no that's not it at all. It's clearly a poorly written post from over a year ago. I don't think anyone was cranky. People just have a hard time reading that hodgepodge.
Okay, I see that the OP came back a year later to defend his post.
Why jow? Yu must not be married man to not know to let past mistakes stay in the past.
LOL! 42 yrs with my wife. I did not see a true mistake to cause the negative replies. I let it go initially because I do not deal with negatives replies. I spotted the reply in a search and wanted to see possibly what went wrong. People are People as my Grammar and Errors, “Life Moves On”. Thanks to all of you and I have moved on to my next PM.
Just giving you a hard time man!
Jesse1
