RysiuM
2012 4Runner SR5
Let me start with two facts:
1. All LED bulbs I got in Amazon or Ebay are overrated by sellers. This is true not only for cheap "made in China" bulbs but also sold by "USA sellers". I am not talking about the quality of the LED bulbs but true light output versus the data provided by sellers.
2. For LED lighting the most important value is light output (given in lumens) not light intensity (given in candelas). It is not important how bright the bulb is when you look at it, but total how much light it gives out. It is easy to be mislead by the LED brightness especially when compared to incandescent light. For the same light output LED always is brighter than equivalent incandescent bulb because of different light spectrum (high color temperature light looks brighter than low color temperature light) and different light intensity (all light is produced by a relatively small LED area compared to incandescent bulb. It may blind you, but still will not show the way
So knowing that you can't be fulled anymore by less than honest suppliers. Each bulb I'm buying I measure, test and often take apart to see how good and reliable design it is. I am not looking at the bulb, how bright it seems, but I compare them shining on the tissue side by side like for example on this picture.
At the same time I'm selecting the bulb design not only for the matching socket type and dimensions but also for the fixture where the bulb will be installed. For example for map lights and dome light you don't want the brightest and and blinding light output as when you drive at night and your passenger tuns on the light you don't want to be blinded by your own lights.
So here is my setup so far - you can agree or not, but I thought about this subject a lot and decided to create my own custom set of LED bulbs and not going for ready available "Interior LED Replacement Light Bulbs Package Set".
Driver and passenger map lights: JDM ASTAR 10pcs Super Bright 194, High Power 5630 SMD 6000K LED Bulbs. Actually each bulb takes about 60mA and uses "buck" type driver (not resistor) so actually most of the power goes to six 5630 LEDs. Each bulb takes about 0.7W with total light output about 80 lumens. That is about two times more light output than original stock 5W incandescent bulbs.
I was considering similar bulbs that contain five 5050 LEDs (in similar orientation) but the bulbs I used have actually two 5630 LEDs on the top of the bulb (pointing down from the ceiling) so they actually give more light where I needed it.
Driver and passenger site vanity mirror lights: It should use bulbs that have LEDs on one side but I couldn't find 194 bulb in such LED orientation so I used the same bulbs as I used for map lights.
Dome light is quite tricky: I wanted to go with the large light output as I could, but to much light is actually not good for driving at night when someone on the back sit decide to turn the dome light on. So I decided to go for 3110-W10-CB from superbrightleds.
Actually it is very well designed and made bulb. I has "buck" type driver powering ten high efficiency 4014 Luxeon LEDs. It has CANBUS resistor (which I don't care about anyway) and aluminum heat sink to get rid of some heat. The light output is about 100 lumens which looks OK inside the cab. I wish they could have the version without the CANBUS resistor.
On the other hand the tailgate lights should be as bright as possible. Original incandescent bulbs don't light much inside the cargo space, so here I went "bananas". I bought quite expensive "9w Cree LED 31mm Canbus No Error Festoon License Plate Interior Map White Lights" by SiriusLED on Amazon. Here is the picture of this bulb
I have decided to spend 9 dollars per bulb because they used high output LEDs rated at 3W each (max at 1A). However the bulb circuit design i very poor. It contains 47 ohm resistor in series with 3 LEDs and one diode (reverse current protection). The actual power run through LEDS was about 0.5W (not 9W) and the true light output is only 80 lumens. Not much for 9 dollars bulb. But I knew I could do much better. I bought NSI50350AST3G (350mA constant current driver) for 60 cents from DigiKey and installed it instead of 47 ohm resistor. I have removed also CANBUS resistors to make room for this IC. I have also removed plastic from each end of the bulb (it was melting from the heat) and replaced it with epoxy. This is how it looks the "big ass DE3175" bulb (Picture taken before replacing plastic ends):
Now I have true 3W bulb with light output 480 lumens - that is equivalent of 30W incandescent bulb. Big improvement from the original 5W bulb. Now the cargo space is well lit just by tailgate lights alone.
My next step is to replace puddle lights in mirrors. For that I have bought WLEDB-CWHP9-DAC from superbrightleds. This bulb has nine 2835 LEDs powered by "buck" type driver. The bulb takes 130mA (1.5W) with total light output is about 130 lumens. The good thing is that all the light is facing down (where it should) not like bulbs from a "kit" all the way around. The only unknown is: will it fit through the opening in the fixture. I will try to install it tomorrow so I will know. If it doesn't I will have to modify the bulb to make it fit
