N Fab Nerf Bars
Mine have held up well to salt, but I'm starting to notice some rust where the powder coat is failing in the smaller holes in the step plates. Not a huge deal since they're meant to take abuse, but they've held up well for the 4 years I've had them. I have sliders to replace them with, but I'm not in any hurry since they're on and they're functional as steps
4 years is impressive. you could contact nfab actually and get a new set under 5 year finish warranty. I contacted nfab to ask specifically about rust in the northern climates. I was told I could remove the end caps and use spray foam filler to help prevent moisture from entering the tubes and/or just seal the caps on with silicone. any rust I'd be covered under warranty
nfabs aren't cheap up here, they are $500+. brine is used heavily up here along with chunk road salt. some had said line-x them , but that's another $200+ when nfab could just do a better job on the powder coat. everything rusts, I get it, but hearing some people having rust after 3 months is unacceptable. I might take a chance on them, have to think about it some more
Here’s my 2012 sr5 w/ the shrockworks rocker panels and the 3” nfab steps
Did you have to remove the original rocker panel guards?
I have a 2012 limited and I think the original panel guards are making it hard for the brave bars to fit.
I read online some people also buy fender molding caps for the front and back.
I guess my question is did you need to buy those caps with the Shrockworks panels?
AndiGarage
