Navigation override software
You can do this type of "Override" in older units, it just requires modifying the harness some so the navigation no longer "sees" the vehicle moving. Apparently popular enough that some tech savy guys make a side job cutting up LX470's and such for picky owners.
Disc
I'm familiar with this seller.
The disc is a hybrid of custom software and the latest 12.1 updates.
Prius cars are not always accepting of this disc, but otherwise works like a charm.
Sorry for the late response to above post. Yes, I got it to work, but it took some effort. When the installed new 12.1 DVD wasn't working, I ended up doing the following:
o unloaded new 12.1 DVD
o turned key off, waited a few seconds, loaded old 11.1 version
o turned key off and waited a while
o turned key on and unloaded old 11.1 version
o turned key off and removed radio fuse in engine compartment
o waited 30 seconds (I think instructions say to wait 10) and reinstalled radio fuse
o turned key on and notice radio presets were gone
o loaded new 12.1 DVD
o system loading progress bar appeared on screen (working!)
o tried tapping top left corner, then bottom left corner, then top again, then bottom again... menu popped up with override option on left side
I had tried variations of the above sequence (like removing fuse after removing 12.1 version and trying to reinstall new 12.1 version), but nothing worked until I tried this sequence. Looking back, my guess is we need to wait 30 seconds after removing the radio fuse, not just 10 seconds.
Lost radio presets and my maintenance reminders, but no big deal to reprogram them. As with any new DVD, one must also set the region.
The link to the Craigslist ad at the beginning of this thread doesn't work anymore, but Jason may have created a newer one. He responds to e-mail questions and seems easy to work with.
I'd like to override but more important I'd like my navigation to be more current, is 12.1 the current DVD? It's my understanding the new DVD's don't work on older trucks.
Curious on that also, my 08 is missing a lot of roads these days, would be nice to update, might as well add the override in the process. Any more input on this, or a current link?
I recently purchased the override DVD. Works good with updated data. Since then I noticed ad pulled from Craig's List. Might check back there.
if you have a 2006 or newer this will work for you. If you have a 2005 orolder like me than you're out of luck.
I just pinged Jason again. Will let you know if he responds.
Jhunt
