KidVermicious
I have not checked the fuel pressure ( i lack the gauge). I replaced the plugs when we did the head (less than 300 miles ago).
Right. What he's saying is, pull them now and see what they look like. The condition of your plugs can sometimes tell you what's going on in the combustion chamber.
Starting fluid should not have messed up the AFM. It's just a flappy door on a potentiometer, it's not like a MAF where's it's sensitive to different chemicals or gets cranky when it's dirty.
Also, I'm still baffled by your vacuum advance hoses and wonder if you have a 22R distributor on there. The 22RE has an electronic advance setup. If you have vacuum hoses on the dizzy, then I'd like to see pics of where those are coming from on the manifold and/or valve cover, and I'd like to see a pic of your ignition coil on the drivers inner fender if you have a minute?
