I bought a used in good shape from what I can tell 2004 4runner sport V6 4wd 60k miles. I am assuming other than the normal oil changes that nothing out of that maintenance realm has been done....
NOW: What I would like to do is replace/grease/change and whatever else I may need to do to catch up on or make sure that at the very least, if it wasnt taken care of when it was supposed to, that it is taken care of now. From what I can tell, the oil was just changed by the dealership, but other than a squeal from the brakes nothing is obvious. Im going to replace the pads and probably the front rotors as they have a little groove to them and that needs to be corrected. I can read and am pretty hands on, and will get dirty, so i am willing to do this myself!! THE QUESTION I HAVE IS= WHAT DO I NEED TO DO TO MAKE SURE EVERYTHING HAS BEEN MAINTENANCED THE WAY IT SHOULD HAVE BEEN, SO WHAT DO i NEED TO DO? A LIST WOULD BE VERY GOOD! ANYONE CARE TO HELP ME OUT? Thank you in advance! :bigok:
oil, ZIRKS??, transmission fluid, rear differential??? grease...etc!!! spark plugs? any help in any area above other than oil and anything else you see that I(which I am very sure) i have left out......
