ice
I need some helps here, it happened last night when I try to get home after work. I started my runner and discovered VSC Trac, VSC Off and ABS light on. And I can't even shift from P to D. After checking on the menu, I can override and shift to D by press the override button. However, the indicator light are still on. Does anybody experience this before? I tried to do some search here but the only thing I can found is VSC light on.
thanks in advance
thanks in advance
