Need Help, can't shift from P to D.
ice
I need some helps here, it happened last night when I try to get home after work. I started my runner and discovered VSC Trac, VSC Off and ABS light on. And I can't even shift from P to D. After checking on the menu, I can override and shift to D by press the override button. However, the indicator light are still on. Does anybody experience this before? I tried to do some search here but the only thing I can found is VSC light on.
thanks in advance
There's an outside chance that your wire harness on the ABS system is loose or un plugged (people sometimes un plug this to "disable" the VSC on pre 2008 models which have a switch). Unfortunately, I doubt its that simple. I would take it in for a diagnostic test. Dealer or trusted and UTD mechanic should do.
Try this first:
Disconect the battery for 30 seconds. Reconect, and your OBD comp should reset.
freddygino
