Need help diagnosing problem.
Rc4r
picked up a 97 sr5. build and pics later...
when fully floored the vehicle makes a loued squeal. only when floored though.
it sounds like metal on metal type squeal.
any thoughts?
Does it matter what the speed is when you floor it? If you floored it from a stand still or on the highway going 60 would it behave differently? Try it with your a/c off to rule that belt out. I seriously doubt it could be brakes since it happens when you are accelerating but I don't claim to be an expert
Well its got some exhaust and I can't hear sh*t over it
It's most likely a belt. When you get up to high RPM's especially when the fan clutch is engaged a slightly loose belt will squeal like a piggy.
I wouldn't worry about it too much. I have had belts that were so loud you can't hear yourself think. Check them tomorrow in the daylight and see if they are cracked or worn. I replaced all mine shortly after I bought it because they were yelling at me and giving me a complex.
Jw how mamny miles when you bought
140-ish. I replaced all but timing belt around 155-160. Didn't mess with timing belt since it was done at 99. I did the timing belt at 220-ish again.
Ahh okay. Well there is one bad thing about the runner. 285s in the back and 265/70 in the front? Haha
I agree its probably a belt, hose them down with water and try it again. It could also be an idler pully with a bad bearing. Only other thing I can think of is a clogged trans filter. The trans oil pump can make a high pitched noise if its sucking against a clogged filter.
Josh, that is the plan!
But anyways its desert dune. But I think I'm gunna use the extra $ to get it painted black
