Need help on 3rd generation interior LED light swap
The DOME LITZ (12 led panel) at Advance Auto Parts is number 77254. These are AWESOME and inexpensive and LAST FOR YEARS! They also come with all the adapters you might need.
I need some information to those who have swapped LEDs into the a limited with the digital AC, once you swap the bulbs over does the middle part where it shows the temp and the position stay on? I did the LED swap yesterday and the middle part is always lit up now. Also I would not recommend anyone buy the neowedges from Superbrightleds.com. I ordered some to replace the etc/rear window switch and they would not fit at all.
ok, what about the turn signals, would a flasher be required. i read on that link that the stock flasher might not be able to handle the leds
My front turn LEDs required resistors. When I switched my rear brake/turns to LEDs I had this bizarre situation that every time I activated a turn signal it would also activate my brake lights...I found this out because it would cancel my cruise control every time I would signal to switch lanes...I never figured out why this happened nor an easy fix...just switched the tails back to the originals. Some other threads suggested something to do with my hitch wiring.
Hope it al works out for you!
sylvania.com has a pretty good online auto replacement guide. Found a lot of part numbers for lights through their site
The middle part does stay on for me. I ordered all of mine from superbrightleds.com too and didn't have any issues.
I hardly doubt this is a reason to tell everybody to not buy from SuperBrightLED!
Post up which bulbs you got that wouldn't work.
I mean't not to buy the neo wedge type a from them. The ones they sent me would not fit in the wholes where the factory ones came out at all. It seemed like the base that held the LED was too big.
You ordered the wrong bulbs then. I bought all of mine from them including the Neo-wedges, and they worked just fine on mine.
I ordered the right bulbs because the fit in the climate control which are the same size. I went by what size the chart said to get.
I used the same chart as you PHD. The one MstudT posted. My 1999 limited with the auto a/c required the neo4 and neo3 bulbs. If the neo4 didn't fit, try the smaller neo3 (3mm). The chart on page one is spot on, just take your time. I pulled everything out and did the swap at my kitchen table with a beer or two. :thanks: mstudt for the write up.
Hey all,
I've done the LED UPGRADE... They're bright and they work great... My thing is that the whole fixture need to be replaced... The toyo Switch/System is just worn out..
Does anyone know of a replacement fixture that i might be able to incorporate the current Super bright system i have.. I mean if i have to get a replacement from Toyo.. then i'll go that route. The small spring and "BB" to make switch contact is just worn out.
Thank you.
044runner4
