Need help! Scion T1806 Radio Install Problem
Igot1too
Hey guys!
I've been here for a few weeks and have got some great ideas and tips.
I thought I did all my research and read all the threads about installing a Scion head unit but maybe I missed something.
I can't seem to get the unit to work - wondering if I may have a bad HU??
Here's the stock radio I pulled out:
Front
P1010984-1.jpg~original
P1010985-1.jpg~original
And here's the unit I'm trying to install:
Front
P1010987-1.jpg~original
P1010988-1.jpg~original
Also pulled out what I think is an amp??
P1010989-1.jpg~original
So now I'm left with 2 plugs and 2 antenna wires:
P1010993-1.jpg~original
I understand there are different opinions about what to do with the small antenna wire but for now I'm not hooking that up.
***MY PROBLEM***
With the 2 plugs on the harness plugged into the HU and the large antenna plugged in I tried it out....
-No display
-No colors at all
-The antenna seems to go up and down constantly when I push any buttons
-The radio works but I can't see what station its on BUT the volume doesn't work and it's barely loud enough to hear.
- CD doesn't seem to work at all
- Ipod doesn't work at all ( I purchased the cable)
Any ideas? Did I miss a harness?
There are 2 other places on the back of the radio with nothing plugged in. Maybe those are for the steering wheel?
I don't know.....
Thanks for any help.
Hey guys!
Front
Front
***MY PROBLEM***
-No display
-No colors at all
I don't know.....
The original unit appears to have a 20 pin plug which is like the JBL systems. However I don't see the 20 pin plug on the amp. Was this amp plugged into the original radio?
Thanks for the response.
The amp does have a 20 pin plug on it. That plugs into the toyota radio.
The 4 runner harness has 2 plugs, a 10 pin and a 6 pin, that plug into the amp. Those 2 plugs now plug right into the Scion radio.
I don't think I have the JBL system, however I do have a factory amp. Is that normal?
I also noticed posts #'s 5 & 6 from this thread, CO_flyfisher also had an amp that he took out.
http://www.toyota-4runner.org/audio...807-install-3rd-gen-99-limited-pic-heavy.html
You don't need the factory amp... You seem to have everything correctly!
Your scion unit has a built-in amp, right?
It literally should be plug and play.
I installed a scion head unit into my '88 runner and it was the 2 plugs and antenna.
Did you pull the negative battery connector before removing/installing the radios?
Joel
Joel
Ok, that's what I'm starting to think. (everything is right) And, I think the Scion radio does has an amp built in.
I didn't unhook the battery but the key was off.
I put the stock radio back in for now and it still works fine. I'm glad I didn't cut the bezel yet to fit the Scion radio.
I think I got a faulty unit....
yep, sounds like a faulty unit.
in the future, remove the neg cable from the battery before doing any electrical work on your rig.
that way you can rule out a possible short.
good luck.
joel
Cool thanks for the input guys. ;-)
I'm gonna send this one back and get another.
I post an update when the new one comes in.
