Need help with a 2nd gen t4r swap into a 81 pickup.
acarroll
Well I need some help, tips, and tricks to get this thing wired up and on the road again. What I got going on is a 91 toyota 4runner 22re getting put into a 81 toyota pickup. Wiring is giving me a hard time, so I figured I'd finally ask for some help. I have a few questions to ask but I will start with the simplest one first.
I have 2 plugs which I dont know what they go to, because when I bought the motor there was nothing going to them, here is the picture.
SSPX0039.jpg~original
. I believe most of the wires I need is in the gray triangleish plug aka [IH1] plug in the 91 4runner wire diagram book I have.
Now since my search for the missing Relay Block Assembly has proven to be fruitless or WAY expensive, my buddy found a block from a 90 pickup with a v6 in it. It has an EFI relay, charge and efi fuses, and Head relay. If these are not enough to wire it in with the 22re engine harness any info would be helpful. Also it has the 80A, 40A, and 30A main fuses too. and a 2-3 ft pigtail out of the box, and has the battery cable too.
Sorry for the long thread, this project has been kicking my butt for a long time.
Andrew C.
Oh good point. Those are hanging off the 91 harness, and both plugs are in close proximity to the ECU plugs.
andrew c.
