Need help with Caliraised 8 switch system
ThinblueMN
I bought the Caliraised 8 switch lighting system with the panel, which is a cheaper version of the Spod. I wired up everything as the two page instruction stated, which said to add the add a fuse to the ACC (AC fuse)fuse to get juice to the interior panel. When I do that the panel is constantly on, how do I get the interior panel to turn off when the car is off?
Ok I might of confused the ACC fuse with the AC fuse which is located in the engine compartment vs the ACC fuse which is inside the cabin. Can one of the expert confirm this?
Just did this install last night, I used the fuse adapter sent with the package to connect the red wire to an INJ fuse. Hope that helps!
DionicioLives
