Need ideas!
tor-redneck
i got my 87 body swapped on to my 85 frame. i had to use all the harnesses from the 85. i (think) i have every thing hooked up.... and it isnt runnen. fuel pump is working. get a nice mist to the cold start when cranken, but it fires up for a second and then dies. i gave up on it for the day. gona be back at it tommarow. i have tried both ecu's, ignitors and both circut open relays..... :gun4:
better mention, truck ran fine so im sure its something i didnt hook up, swapped every harness so ofcourse theres something i may have over looked. a few of the conectors under the steering wheel dont seem to have a home, as well as some by the ecu. when it fires up and then dies i can swear that on occassion fuel is getting into my exaust. it seems to weep out a lil where the cat is attached.... i hope i didnt hook up a fuel line wrong lol.......why can anything just be easy?
Is the MAF plugged in? I've been stupid and have gotten so mad due to my engine not running, then I realize I didn't plug in the MAF. :tinfoil3:
Might as well double check all connectors for good connection while you are at it. I managed to install the TPS wrong by not lining up the positioner right. Wouldn't run - ECU thought the pedal was floored.
As many have mentioned, the AFM is a good suspect. Make sure the flap moves nice and freely.
all the super obvious shit is right. my fuel pump was suspect before this so im installing a new one in the am. if it still wont stay runnen ill check codes and go from there.
just to let you guys know it ended up being a bad efi main relay fuse or what ever you call it. i didnt test it but had 2 and figured hell ill try it. fkr fired up and purred! thanks!!!!good day at the ranch lol.
Ambrose67
