Need input on USB file types
Nuke
I've been "RIPPING" (no pun intended) my hair out. I've been ripping music CDs to thumb drives and the only file types that the stock HU will recognize are MP3 and a lower quality version of WMA. I've tried WAV, WMA lossless and WMA variable bit rate. The HU says something to the affect that no useable files found.. I've tried Windows Media Player and a canned app on the PC.
If I have to, I will settle for MP3 but I CAN hear the difference between the CD and the thumb drive. Anyone have suggestions? Thanks in adavance.
Yep, it sucks. Those of us with CD quality (or better, HDA FLAC) collections have to dumb it down for the 4Runner head unit. You aren't missing anything. It won't play your non-compressed files.
That's just odd. The Toyota OM for the audio system (page 123, 124 for my 2019, IIRC) implies the head unit can read a few different WMA versions as well as FLAC and WAV from USB. Or I could be reading it wrong. Thanks.
Page 122 of my 2019 OM seems to say mp3, wma, and aac are the only supported file types. Don’t see anything about flac or wav.
Bit rates:
Mp3(mpeg 1 layer 3):32-320
Mp3(mpeg 2 LSF layer 3): 8-160
WMA v7,8: CBR 48-192
WMA v9: CBR 48-320
AAC: 16-320
I have a large FLAC collection. I just made another folder and did an MP3 320 copy of my collection. I use it for my Camry and 4Runner. I got tired of dealing with issues and just went the most compatible format.
At MP3 320, you can't tell the difference from lossless after a clean conversion. Especially in a vehicle. You can tell the difference between the actual CD player and USB. What you're probably hearing is a difference in signal levels and OEM EQ for compression that is in newer music as far as I can tell. I have heard it. You either have to deal with CD's or accept the limitations along with the convenience of USB.
I use an IASCA cd to setup, calibrate, and EQ my system with a measurement mic. I then adjusted my method of conversion to better match the rest of the system. I use dBpoweramp and found certain settings that work well. I have a 900+ song collection of 80's music in one big album. Most of it is not compressed but some of the later stuff is. I despise constant volume adjustments more than using a touch of gain per track. When converting, I use the EBU R 128 (track gain) and set it at 0db. Audiophiles (Audiofools in most cases) will cringe at the notion. I have actually gone as high as +6db when experimenting in our new Camry. The JBL is terrible when playing non-compressed high dynamic range music.
At the end of the day I have an easy use USB drive that sounds great and matches well with other sources.
Make sure your formatting your usb drive with fat32. I use a 64gb usb drive with my mp3 music at 320 bits and it sounds great although the factory sound system and speakers are terrible.
Well, I'm nowhere the geek I was 30-40 years ago but I managed to rip CDs as WMA and the HU is reading it and it seems to sound better than the same files I previously ripped as MP3.
Thanks for all the input.
I think wma maximum bitrate is 576kbps compared to 320kbps of mp3 :-)
AndiGarage
