need more suspension advice
T4Rscott
Hi,
I need to know if OME 906s and a 1 inch front spacer on top would work. Would it sit level? I also have some 1.5" rear spacers. Would those work better? I am trying limit sag in the rear with the weight of a large dog or 3-4 bags of soil for the wife's garden.
Scott
The 906's and front spacer would work. I don't know how level it would sit, but if you level a car and load the back up with stuff, the back will drop and look like you're sagging, that's why every single truck/suv has some rake from the factory.
Try your best to avoid spacers if you can. They often ruin the ride quality.
906s in back
and 99 tall or OME 880 coils up front is my rec. I had the 906/99 set up for a while and it worked out really well.
906s should be good for 2" out back. 1" of rake would let it sit level when its loaded. I agree with 99 talls and 906s would probably make you happy.
Edit: or a smaller front spacer. If I'm not mistaken the thickness of the spacer creates double that amount in lift up front.
