Need new tires (stock) 265/65-17
Icepuck72
I searched, nothing came up that is really helpful....I'm due for some new ones on my '04. 265/65-17 is the size.
This isn't used for off-road, but don't want just a strictly highway tire. We do go skiing once in a while and would like something with a little bite for those occasions.
I was looking at these.....
BFGoodrich Radial Long Trail T/A
OR
BFGoodrich Rugged Trail T/A
Any thoughts?
Personally,I think both of those choices are too aggresive a tire for the use you stated.
I suggest going to tirerack.com and doing a search on tires by size. I have the same size and I believe there are some decent choices. Too bad the stock size isn't 275/70's or 75's. The ride would improve but they'd throw the speedometer out. It can be adjusted, though, from what I hear.
EDIT: I take back the "too aggresive" comment but still think you can do better. Check this out:
http://www.tirerack.com/tires/surve...dth=265/&ratio=65&diameter=17&tireSearch=true
It's tough to beat Michelin Cross Terrains. Maybe the Fortera would be a good match. There's a fresh thread on the these tires in the 'perf zone' section of the forum. Tirerack.com is a helpful study resource.
If in shopping you think you want to try 265/70/17's they'll fit. They won't throw the speedo off enough to worry about. They won't rub. The mpg would probably be a wash... The reason I mention that is as you research you'll discover there are more choices in that size and if you're price sensitive they tend to be cheaper.
:cheers:
im looking half way into the general grabber HTS....seems pretty good for not a whole boat load of cash
